Mikuni CarbsThis is a discussion on Mikuni Carbs within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; does anyone know anything about mikuni carbs? i have one off of a suzuki quad runner and don't know where ... |
| does anyone know anything about mikuni carbs? i have one off of a suzuki quad runner and don't know where the vaccum lines hook up? i need some help. anyone? its the style with a diaphragm in it, roughly around 30 mm. My fuel pump also is leaking a bit. could this have something to do with it not getting any fuel to the carb.? |
| The gas inlet nipple should be pointing up on the main part of the body,the vent will be sticking out horizontally from the main part of the body and the overflow will be pointing down from the bottom of the bowl. Not sure what model you have but this is pretty standard on the LT mounted Mikuni's.If the diaphram in the fuel pump is bad it can leak fuel and also cause it to not work. I hope this helps. |
| Yamaha carbs. | Kanookie | 2-Stroke Motorcycles - Yamaha | 3 | 04-08-2008 09:15 AM |
| Banshee carbs | bowersz | ATV/UTV - Yamaha | 3 | 09-03-2007 11:57 PM |
| question about carbs. | soccer2963 | 2-Stroke Motorcycles - Yamaha | 1 | 09-14-2005 07:43 PM |
| rifled carbs? | suzuki29 | 2-Stroke Motorcycles - General Discussion | 6 | 04-18-2005 07:39 AM |
| carbs? | magnethead | ATV/UTV - General Discussion | 6 | 05-19-2004 08:30 PM |
