Leaky gas tank please help!!!This is a discussion on Leaky gas tank please help!!! within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; After about six rides yesturday we found that my tank started to leak. I need somthing to seal a plastic ... |
| After about six rides yesturday we found that my tank started to leak. I need somthing to seal a plastic gas tank. Ive read kreem, but all i can find is for metal tanks. This tank is custom plastic welded together. A new tank isnt an option. This is for my crf/gasgas 230. I want to be able to ride by momorial day. Thanx |
| Once you find the crack, take out the tank and drain it, clean around the crack really well and make sure there is no gas coming out. I have found that if you use a good urethane epoxy (the kind where you have to mix the epoxy and hardener), it will seal the tank (if the crack isnt to big) and keep the crack from getting larger. Make sure the epoxy is gas-resistant, and then wait for 24 hours before filling it with gas. You should be able to get a tube of it at an auto parts store for a few dollars. Hope this helps.. -Mike |
| That or just get a plastic welder from somewhere like rocky mountain and weld it up. |
| piche, i'd go for the epoxy. my feind fell and he cut a small hole in one of the crankcase covers and was dripping oil. he took it off and put some epoxy on the inside and it hasn't leaked since. |
| Thanx for the replies, we epoxied the livn #$%# out of it hopefully it will hold at least for the long weekend....... |
| Leaky Head Gasket | Wavfact | 2-Stroke Motorcycles - Honda | 13 | 09-20-2007 12:46 PM |
| leaky exhaust flange | CR-FLAVOR | General Discussion | 4 | 04-19-2005 08:28 PM |
| Leaky seal? Rebuild help | Crazy | 2-Stroke Motorcycles - Suzuki | 3 | 03-16-2005 07:27 AM |
| Leaky radiator? | Amanda | General Discussion | 8 | 11-30-2004 06:32 AM |
| leaky petrol tank | coops | General Discussion | 9 | 09-05-2003 10:07 AM |
