Kick starter
This is a discussion on Kick starter within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; My kick starter seem to be loose I mean when it folds up it as alot of play and tips ...
Old 04-24-2005, 07:17 AM
Last Online: 10-07-2006 05:26 PM
Default Kick starter
My kick starter seem to be loose I mean when it folds up it as alot of play and tips on fixing that? doen't want to hold agains the bike.
Thanks
Randy
Old 04-25-2005, 12:06 AM
Default Re: Kick starter
What kind of bike???
Old 04-25-2005, 12:10 AM
KKXR400R's Avatar
V26X INT
Last Online: 11-19-2009 07:54 AM
If its an XR.......don't worry this is normal
Old 04-25-2005, 06:45 AM
2003 yz125 some one told me I could adjust it. That try I ask
Old 04-25-2005, 07:59 AM
nicster's Avatar
MoreFaster is MoreBetter
Last Online: 08-20-2009 08:37 AM
My advice would be to look at your service manual at the assembly and see how it goes together. Once you know that you can see what you can do to make it tighter. Or just look at it I can't imagine there is too much to it.
Old 04-25-2005, 10:06 AM
99kx250rules's Avatar
Last Online: 03-16-2009 12:22 AM
Thanks
Randy
There should be an allen head bolt that has a spring and a little ball bearing in front of it (on the inside of course). Tighten that allen head and it should remove the play. If it doesn't then maybe the ball bearing fell out.
Old 04-25-2005, 11:17 AM
Chadm89's Avatar
Witty headline goes here.
Last Online: 04-07-2008 10:39 PM
I just fixed this same problem on my CR125. On the inside of the kickstarter there's a spring and ball bearing that sit inside of a little "cup" and the spring presses the ball bearing out against the kickstarter, which creates the pressure to keep it in place. Mine was so loose that when I'd start the bike, the kickstarter would just vibrate out to the "open" position. After replacing the spring and bearing (3 dollars for both from Honda), it's fixed and doesn't do that anymore.
Your kickstarter might be assembled a little different, I can only speak for my '94 CR125 but it's probably not too different from bike to bike.
Similar Threads for: Kick starter
kick starter not returning HEAVY HITTER 2-Stroke Motorcycles - Yamaha 5 03-19-2009 11:13 PM
Kick starter gear removal dixienw123 General Discussion 4 04-03-2005 12:10 PM
need help/kick starter siezed bansheeridder 2-Stroke Motorcycles - Yamaha 5 07-14-2004 01:34 PM
kick starter on 400ex Newf_Rider ATV/UTV - Honda 6 03-28-2004 03:26 PM
Kick Starter RaceyCRF250 4-Stroke Motorcycles - Yamaha 2 01-15-2004 08:37 AM
