Old 07-21-2004, 09:21 AM
Crazy's Avatar
Last Online: 01-19-2014 09:57 PM
Default Re: I'm a traitor
well what can i say i like the lazy boy seat compared to your ktm. Id bust my rear end the first time it came up and smacked me off a jump
Old 07-21-2004, 12:05 PM
My son has a 2000 with more changes than i can remember. one change he made in 2001 was to a 2001 cylinder and carburetor. He went back to the Keihin within weeks. If you want a little more response, it is a cheap way to get it (changing to the PWK).
He has a reworked shock and forks. According to him it didnt do as much to improve the machine as stiffer springs did. You may want to try that before you spend any money valving the suspension.
If you are not racing it, and it gets to be time to replate the cylinder, consider one of the oversize piston kits and some porting. Then you will likely be in the market for a flywheel weight. Like the CR's that came before it, the one you have is pretty bullet proof. If you want to make a real cross country rig out of it, there is still a wide ratio gear set that will work with the 2000 and the 2001. (It is designed for the crf450, but the 2000 and 2001 use the same transmission shafts and it is a drop in). Baja Designs sells the one I speak of. I wish that Honda had stuck with the same shafts in the 2002 and later CR250's.
Old 07-21-2004, 03:50 PM
Crazy's Avatar
There we go sorry all my picture wasnt showing up my server comp crashed
Old 07-21-2004, 04:34 PM
huffdaddy70's Avatar
Last Online: 02-28-2012 08:04 AM
Nice ride bro!
Old 07-21-2004, 06:14 PM
Z mann R2's Avatar
Last Online: 05-28-2010 06:23 AM
your PM's are full so i have to ask you on here? if you dont mind me askin? how much did you get that bike for?
Old 07-21-2004, 09:53 PM
Crazy's Avatar
Reasonable!!
Similar Threads for: I'm a traitor
THINKING about becoming a traitor RMZracer212 General Discussion 22 02-27-2006 11:39 AM
