Old 10-04-2013, 10:06 AM
86CR's Avatar
Last Online: 11-02-2015 11:37 PM
flasher How long will it last.
I have an 95 CR250R i ride kinda like a trail bike. I ride alot of open back roads an will occasional pull wheelies, Do jumps, and crack down on it. It fires up first kick an has power. But my question is if you just like rideing an arnt raceing it. how long can you scrape by without haveing to rebuild it. As long as it gets me were i want to go i see no point in a rebuild.
Old 10-04-2013, 10:49 AM
bjunior's Avatar
novice
Last Online: Yesterday 11:02 PM
one thing u did not say how fresh or when the top end was rebuilt. if u bought the bike
without replacing top end or bottom end or checking crank for play. its a crap shoot.
as long as its u where u r going is wrong cause once piston goes u r looking at a complete rebuild top / bottom end.after a bout 15 or 20 hrs i would check condition of piston.
Old 10-04-2013, 11:03 AM
How long will it last? Please let us know.
Old 10-04-2013, 12:29 PM
Silver_Fox's Avatar
Last Online: 02-22-2017 10:36 AM
It will easily make it to the point of where it quits.
Old 10-04-2013, 12:40 PM
86CR's Avatar
Default hahaa ok
I will let you guys know how long it lasts, I take care of it but i see no point in replaceing something unless it needs it. So if it runs then i dont need to mess with it. But the top ends fresh An will promb never be changed unless it stops running.
---------- Post added at 09:40 AM ---------- Previous post was at 09:34 AM ----------
If she gets to the point to when she quits then it needs rebuilt thats just my belief if its not broke dont fix it. An besides im not out raceing i was just wondering the longest you can go before it really dies an needs repaired I figured it would last just as long as a 4stroke it would it might just lack power.
Old 10-04-2013, 12:48 PM
Silver_Fox's Avatar
If it's been maintained well and is fresh it will last a long time, they're a good engine. Just remember your bike doesn't know the difference if you are racing it or not.
As far as replacing parts that aren't broke as you say doesn't mean they are not past their serviceable limit. Certain parts will need replacement even if the bike is working fine.
ps
And has a d on the end of it.
Old 10-04-2013, 01:04 PM
gusco's Avatar
Last Online: 02-07-2019 08:56 AM
I asked a similar question a while back. The best answer I got was to test the compression with a new top end and replace when it's lost 10% (i.e- initial comp. 200psi, replace top end when comp is at 180psi).
Old 10-04-2013, 01:26 PM
stevo450's Avatar
Remember:
'A stitch in time saves nine'
Old 10-04-2013, 01:57 PM
VAL's Avatar
VAL VAL is offline
Last Online: 12-16-2018 04:22 PM
Please call a doctor if it lasts over 4 hours.
Old 10-04-2013, 04:23 PM
As long as your tires have air in them, you wont need to replace them either.
---------- Post added at 04:23 PM ---------- Previous post was at 02:33 PM ----------
Seriously, mx motorcycles are high rpm machines. They don't usually just die in their sleep. Most times, when something fails, it is a catastrophic failure. That means, when a part fails, it usually takes out the whole engine. A 2stroke engine will cost around $600 in parts to fix when this happens. That is why most of us do routine maintenance on our engines. For mx bikes that includes periodic top end rebuilds. Your engine may or may not, need this maintenance. Only you know, and if you don't, it is a gamble.
Old 10-06-2013, 06:46 PM
86CR's Avatar
Default 145
I tested The 95 Today with a compression tester an got 145-150 psi. I didnt know i was supposed to hold throttle open so it might gain a little. but its there right now. Im not going to let beat the bike an neglect it but once it gets down around 100-110 i might rebuild it.
Old 10-06-2013, 07:52 PM
Papagonz's Avatar
Last Online: 05-11-2016 05:04 PM
I would at least change the rings and check the rod bearing for up and down play; you will gain compression, more compression=more power. While your in there you can see where it's at in its service life.
Neglect to do this and a catastrophic failure could be looming...
Old 10-08-2013, 07:57 AM
86CR's Avatar
But yea i got 145-150 out of it. I tested the old 86CR and it got the same thing. But its wierd where as the 95 starts first kick an has crazy power the 86 usally starts on 4th kick an has power but not enough the match the 95. I will be doing another test soon the correct way to get more accurate readings an use a better tester.
Old 10-08-2013, 11:51 AM
Silver_Fox's Avatar
When your done working on your bike you need to buy a new keyboard, the "d" isn't working on yours.
Old 10-15-2013, 08:21 AM
86CR's Avatar
Default Doing a Rebuild
Ok so ive decided i will go ahead an see whats in the beast. I believe a set of rings, Vforce Reeds, An good jetting will wake it up a little. i also need to invest in a new chain, sprocket, Chain guide an back tire there getting a little worn. But i cant wait.
Old 10-19-2013, 01:32 PM
1276brady's Avatar
Last Online: 10-17-2017 09:51 AM
Silver_Fox, I "d"on't think he got the hint.
Old 10-21-2013, 09:55 AM
86CR's Avatar
Default HAha
No i sure didnt
Similar Threads for: How long will it last.
How long ossagp General Discussion 2 12-14-2010 07:38 AM
Not long to go! pjg351 General Discussion 2 12-15-2007 05:38 AM
How long? Racer92 Fitness, Training, & Recovery 18 03-12-2007 11:12 AM
Has this been out long? boogieonmyfinger ATV/UTV - Suzuki 4 06-30-2006 12:27 PM
how long crzero 2-Stroke Dirt Bikes - Honda 2 05-04-2004 07:07 PM
