Old 12-12-2003, 09:30 PM
Dirtbikindad393's Avatar
Last Online: 08-13-2018 12:51 PM
Default Help! The Petcock Leaks
OK so maybe my tank isn't such a good deal after all. I put the petcock on and put a cup of water in the tank and the seal between the petcock and the tank leaks. Imagine what would happen if I put it on and filled it with 3 gals of gas.
So whats the deal should I get a new petcock gasket? I flipped it over so it had a new side that helped but that didn't stop it. Ideas anyone does the motorcycle shop even carry a petcock gasket? What a bummer
Old 12-12-2003, 09:39 PM
Yardpro393's Avatar
Default Re: Help! The Petcock Leaks
is it an o ring?
Old 12-12-2003, 09:43 PM
Yes its that type of gasket. Not neccesarily round mind you but Yes.
Old 12-12-2003, 09:47 PM
Last Online: Yesterday 04:47 PM
Try a little bit of silicone around the petcock and/or a new seal.
Old 12-12-2003, 09:51 PM
Woody_YZF's Avatar
Last Online: 01-11-2015 01:36 PM
Take it back and get your old tank back. I can't believe that guy did that.
Old 12-12-2003, 09:56 PM
Thats what I was thinking Woody.
Old 12-12-2003, 09:58 PM
I will bet anything he has already taken my graphics off and everything.
Chase will rtv silicone work on that?
Old 12-12-2003, 10:07 PM
I would think so, but don't take my word on it. I agree with Woody- call the guy NOW and ask him what is up and see if he'll swap back.
Old 12-12-2003, 10:35 PM
TexTwister 393's Avatar
Last Online: 05-13-2005 10:37 PM
Take the seal off and clean it real well and sock it in some carb clean, it will make it swell up some and then try placing it back on and see if that works if not then go get some stuff called Three Bond 1104 its in a yellow and white tube its the best stuff for making gaskets...
Old 12-12-2003, 10:46 PM
04whyzee's Avatar
Last Online: 02-05-2009 01:42 PM
Prob is gasoline is usually corrosive to Gasket Maker so it's not just that easy. Try going to a m/c shop and getting a new sealing ring.
Similar Threads for: Help! The Petcock Leaks
Gas tank leaks YammerHammer 2-Stroke Dirt Bikes - Yamaha 8 09-01-2007 04:44 PM
fuel petcock mark anderson 2-Stroke Dirt Bikes - Honda 6 06-03-2005 04:47 PM
AIR LEAKS kickindirt114 2-Stroke Dirt Bikes - Honda 14 04-11-2005 09:20 AM
Searching for air leaks cr2504life 2-Stroke Dirt Bikes - Honda 4 05-27-2004 01:26 PM
finally- no leaks Yardpro393 2-Stroke Dirt Bikes - Honda 2 08-28-2003 12:34 PM
