Gearing!
This is a discussion on Gearing! within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; Hey guys im here once again to post about gearing. So heres my question...If i go from a 14-50 tooth ...
Old 01-06-2004, 08:25 PM
83SuzukiRM250's Avatar
FordFreak
Last Online: 12-29-2004 10:35 PM
Default Gearing!
Hey guys im here once again to post about gearing. So heres my question...If i go from a 14-50 tooth setup to a 13-51 tooth setup would the power stay the same or would it give me more low end performance?:
Thanks Again!!!
Old 01-06-2004, 09:22 PM
Last Online: 09-05-2004 10:06 PM
Default Re: Gearing!
Since your taking off one tooth from the front that actually makes it lower geared. Plus, since your adding one tooth that makes it lower geared also. So since when you take one tooth off the front it is equal to adding 3.5 teeth on the back. so now you have about 4.5 teeth u just added to the back. Thats a big change in gear ratio and will give u a short pull in each gear but will hit hard.
Old 01-06-2004, 10:00 PM
psyklone393's Avatar
...dress for the crash...
Last Online: 03-27-2006 10:53 AM
bingo.
-Z
Old 01-06-2004, 10:06 PM
TheFouledPlug's Avatar
Unstable Pilot
Last Online: 08-12-2006 11:45 PM
I think that a 14-52 would work betterIMO
Old 01-07-2004, 01:31 PM
FordFreak
Thanks guys i think i finally made my decision. I'm gonna get a 52 tooth rear sprocket and keep my 14 tooth front sprocket.
Old 01-07-2004, 02:30 PM
FordFreak
Should i get an Aluminum or steel Sprocket...just want to see which you guys think is better and if you use it
Old 01-07-2004, 05:42 PM
Faded's Avatar
Last Online: Yesterday 07:33 AM
Here is a neat little way to help you answer those gearing questions:
First, take the number of teeth on the rear, for example 52.
Next, divide that number by the number of teeth on the front, say 14.
52 / 14 =3.71....
You've come up with: 3.71..., what does it mean?
The lower the number = taller gearing and increased top speed.
The higher the number = shorter gearing and better low-end performance.
Peace,
Andrew
Old 01-07-2004, 08:42 PM
FordFreak
Hey thats pretty cool Faded...thanks
Old 01-07-2004, 08:59 PM
paul reed's Avatar
pro class pimp
if you go smaller up front-the chain will have a sharper turn to make and it may increase the tendency for the chain to lift-it is better to make gearing changes to the rear...back when your bike was built-sidewinder sprockets offered two peice rear sprockets for quick gearing changes without removing the rear wheel-they were aluminum and anadized-some guys would run two different colored halves-tRiCK...anybody else seen`em??
Old 01-07-2004, 09:03 PM
FFRacing11x's Avatar
The "ONLY" FastForward
Last Online: Today 10:26 AM
Remeber the HD Baja100??? It had 2 piece sprockets STOCK!
Old 01-07-2004, 09:05 PM
Also remember that sprocket sizes affect the suspension. The smaller the front/bigger the rear the more apt your suspension is to "squat" under load.
Similar Threads for: Gearing!
gearing on a 125 Henry 2-Stroke Motorcycles - General Discussion 17 09-20-2007 10:54 PM
03 yz gearing?? seagrams83 2-Stroke Motorcycles - Yamaha 7 06-26-2007 10:06 PM
need gearing help kdx200rider6789 General Discussion 3 09-09-2004 07:51 PM
gearing? squizzleboy General Discussion 3 06-09-2004 05:12 PM
gearing my 426 lcano 4-Stroke Motorcycles - Yamaha 2 03-24-2004 08:52 PM
