Exhaust Joint Alternitive?
This is a discussion on Exhaust Joint Alternitive? within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; Im trying to think of a way to seal the exhaust joint where the pipe meets the silencer. My old ...
Old 04-18-2005, 11:57 PM
scooter842's Avatar
Last Online: 11-17-2009 06:49 PM
Default Exhaust Joint Alternitive?
Im trying to think of a way to seal the exhaust joint where the pipe meets the silencer. My old one is torn and i am getting spooge on my swingarm, subfame, shock, and rear master cylinder. ITS MAKING A MESS. Im looking for a quick alternitive to seal it off untill i can get another one from the shop. Any ideas? Anyone?
Old 04-18-2005, 11:59 PM
Kenny400's Avatar
Proud Papa
Last Online: 11-03-2009 12:35 PM
Default Re: Exhaust Joint Alternitive?
High-temp (red) silicone works great. OR..if you're not into looks, a piece of heater hose and some clamps will work too.
Old 04-19-2005, 12:06 AM
AaronRider's Avatar
give it some PECKER!!!!!!
Last Online: 02-12-2009 09:50 PM
Im not sure how big the gap is on your joint, but on my four stroke Factory 4 exhaust, I just use hi-temp silicone without a clamp at all
Old 04-19-2005, 12:02 PM
scooter842's Avatar
hey thanks guys for the input i will try that silicone. How long does it last before it starts tearing off or flaking off?
Old 04-19-2005, 12:14 PM
Kenny400's Avatar
Proud Papa
It shouldn't do either until you have to remove the silencer or pipe and it will separate easily when you do. I put it on the inside of the joint and you really can't see it. I remove the silencer, clean it and the pipe end really good with some brake cleaner, apply the silicone to both pieces, and then re-install the pipe and the mount bolts. I wipe off the excess that comes out before it hardens. I recommend letting it cure for few hours before you ride.
Good Luck!
Old 04-19-2005, 12:38 PM
MotoMan's Avatar
Floppy
Last Online: Today 08:39 AM
Yep, my thoughts exactly, RED RTV works great!
Old 04-19-2005, 02:30 PM
dancrf100's Avatar
Last Online: 09-07-2006 05:15 PM
Could i put a small layer off this around my pipe where it meets the engine, becuase there must be a small gap and im getting some spoogy stuff on m engine. Would this be okay or not?
Old 04-19-2005, 06:58 PM
Kenny400's Avatar
Proud Papa
Um..I don't know about your bike, but mine has a couple of o-rings located there in the flange. I currently have my pipe OFF, because I dented it.. ..and used the torch/pressure fix to get most of it out. Anyway, you might want to look into replacing those if it has them, but I suppose a thin layer of the RTV wouldn't hurt. You don't want to go overboard and put alot of it there. It just might give the o-rings some "help".
Similar Threads for: Exhaust Joint Alternitive?
iT425G Exhaust/Barrel joint blow by Denzlepob 2-Stroke Motorcycles - Yamaha 2 09-20-2008 03:08 AM
MRD Exhaust?? Cr250Rider03 4-Stroke Motorcycles - Honda 0 05-13-2008 07:05 PM
Exhaust stfaulk89 Wanted Items 0 01-12-2007 07:44 PM
u-joint for Yamaha Big Bear fubar ATV/UTV - Yamaha 0 11-06-2005 01:39 PM
MRD Exhaust? bLuEcRuSh005 General Discussion 0 01-23-2005 11:34 PM
