Old 02-16-2011, 11:52 PM
supercr125's Avatar
Last Online: 03-02-2016 12:12 AM
Default doh....
i FINALLY got my cylinder back!!!!!11!!!!one1!!!!!1!!!
but then i went to go put it on and youll never guess what happened... the rings that supposedly fit my piston were WAY to wide and even crossed eachother when i fit them in the cylinder without the piston... so now im left to buy a new pair of rings... anyone got any ideas? there .25 over so should i just get standard? there needs to be two rings on this piston since it has two ring grooves, any thoughts? just buy the standard rings?
Old 02-17-2011, 07:52 AM
Mainjet2001's Avatar
Last Online: 07-28-2017 10:28 AM
Do you have a OEM piston and off brand rings? (width)
Do you know what your clearence is between your piston and the the cylinder is and what it should be? (overlap)
Do you have a manual for your engine? (tells you what the ring gap should be in the bore)
Old 02-17-2011, 09:09 AM
supercr125's Avatar
i sent the piston in with the cylinder to get it bored out so they did that there i gotta buy standard rings ill call a shop today to see what to do
Old 02-17-2011, 02:51 PM
Is the piston standard (OEM)?
Old 02-17-2011, 02:54 PM
supercr125's Avatar
nope its NOS (old piston but fits perfect) it looks just like the one that came out of the bike, and im going to get it measured with the bore to know what size rings to buy
Old 02-17-2011, 05:30 PM
Well you said the rings were to wide. I assumed after you sais they overlapped which would mean the rings were not the correct rings for that piston.......does wide & overlap mean the same thing?
Old 02-17-2011, 06:15 PM
supercr125's Avatar
im not sure, it was through ebay, im DONE with ebay....
