Circlip Installation
This is a discussion on Circlip Installation within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; Are there any tips or tricks you can tell me about installing piston circlips? Any special tool I could use ...
Old 04-05-2007, 08:01 AM
Last Online: 04-05-2007 02:19 PM
Default Circlip Installation
Are there any tips or tricks you can tell me about installing piston circlips? Any special tool I could use to help the process?
Old 04-05-2007, 08:50 AM
The Baron's Avatar
Last Online: 07-18-2008 12:40 PM
Default Re: Circlip Installation
I just hook one end in and use a flat blade screwdriver to push the other side of the clip in. Double check it's all the way in the groove and call it golden. A dull smooth flathead will keep from scratching things up.
Oh, make sure there's a rag covering the crankcase so you don't drop it in there.
Old 04-05-2007, 09:46 AM
Last Online: 03-28-2010 03:02 PM
I like to use a bent icepick or an awl with the dogleg type curve in it. I want to feel it turn in it's groove as you face the open end to the direction of piston movement.
Old 04-05-2007, 10:01 AM
yzernie's Avatar
Retired now a House Biatch
Last Online: Today 11:38 AM
Before doing installation stuff a rag or towell around the rod and COMPLETELY cover he space that goes into the crank/bottom end area. If there is any space small enough for the circlip to find its way into the bottom end Murphy's law comes into effect and it will find it.
Whatever method you use just double check and make sure there are not any rough edges along the side of the piston where the round pin hole is located. If there are, make sure to sand it smooth with some 600 grit sandpaper.
Old 04-05-2007, 10:23 AM
YZalltheway's Avatar
Last Online: 11-05-2009 01:25 PM
yea i think they pretty much got it... i used these little hook things that look like a bent icepick, and yea u deff want 2 cover the case i made the mistake of dropping it in there and spent a hour trying to fish it out
Old 04-05-2007, 01:24 PM
Henry's Avatar
Last Online: 05-24-2009 03:56 PM
i learned that the hard way...
Old 04-05-2007, 01:44 PM
The Baron's Avatar
I was able to pull the motor out of the frame, turn it upside down and shake the clip out of my friends bike when he dropped it in. That was just plain luck right there.
Old 04-05-2007, 02:27 PM
Henry's Avatar
i did not know until, it was too late. so i had to redo the rebuild, the worst part it is had just spent $30 to go riding for the day and it blew up 1/2 way through the second lap of the day, i was pissed...
Old 04-05-2007, 05:01 PM
What?? you guys never heard of magnets??
Old 04-06-2007, 11:35 AM
The Baron's Avatar
I just recently bought a new extendable magnet after losing mine a while back. The wife is happy that I no longer need to steal refrigerator magnets to collect the valve shims out of the heads of the 450.
Old 04-06-2007, 12:10 PM
Last Online: 04-08-2007 06:37 AM
Default Re: General
Hello all. new to this forum. Looks like a nice place to trade info/ideas. Later. Tony
Old 04-06-2007, 02:05 PM
Trading is good,,just something about my nature that makes me feel better if I cheated you out of an idea. On mags for retrieving steel from the crankcase: I use a couple of large mags from a motor. I put them on the crank wheels with the cylinder off and slowly rotate the crank. You would be surprised what comes up on the wheel when you do that.
Old 04-06-2007, 06:56 PM
crfjedi393's Avatar
Super Moderator
Last Online: Yesterday 10:13 PM
Now THAT'S a tip to remember!
Old 04-06-2007, 08:09 PM
Henry's Avatar
what do you mean "large magnets from a motor"?
Old 04-06-2007, 08:15 PM
i think that he means from an electric motor like off of a washing machine... u can also use a magnet off of a speaker. my dad uses one on the oil pan of his car to collect any filings, it seems to do the trick
Old 04-07-2007, 12:20 AM
Kx is correct, I should have said electrical motor.
Similar Threads for: Circlip Installation
where can i find front sprocket circlip??? daveythewavey19 2-Stroke Dirt Bike - Kawasaki 7 07-13-2007 02:40 PM
Flywheel installation KKXR400R 4-Stroke Dirt Bike - Honda 6 04-30-2007 08:36 PM
front sprocket circlip! daveythewavey19 2-Stroke Dirt Bike - Kawasaki 4 01-18-2007 05:26 PM
Main bearing installation SirFallsALot243 General Discussion 12 07-08-2005 08:20 AM
Universal installation TexasDirtNap393 General Discussion 12 01-11-2004 06:24 PM
