Old 07-27-2013, 11:05 AM
Derick15's Avatar
Last Online: 06-07-2014 11:56 AM
Default Bought a FMF fatty, can I run stock jets?
I have a 03 yz125. Do I have to buy other jets or jet it with the jets I got now?
Old 07-27-2013, 11:37 AM
Optimum jetting requirements change when a pipe of different dimensions is used. Pretty accurate rule of thumb.
Old 07-28-2013, 07:29 PM
Derick15's Avatar
Can I use it with the jets that are already in my carb? *Stock
Old 07-28-2013, 09:23 PM
stevo450's Avatar
Depends...is it running right with the pipe on it ( doubtful ).
Once your double checked your float height I would dona series of chop tests to see if the jetting is on the money....
Chances are you might be lean....causing other issues...
You'll know if the jetting ( or more than likely the floats are out ) is too rich if your fouling plugs but that is a VERY generalised take on it.
Old 07-29-2013, 11:53 AM
Derick15's Avatar
Don't know much about jetting, but with the stock pipe it runs great. My friend said it all depends if it needs it. I might have someone jet it to perfection
Old 07-29-2013, 12:29 PM
Just put the pipe on and ride it. If it runs good for you, don't mess with it. If you notice areas that don't seem to be right, look into doing what it takes to tune those areas.
Similar Threads for: Bought a FMF fatty, can I run stock jets?
99' KX250 stock carb jets 03 CR125r 2-Stroke Dirt Bikes - Kawasaki 3 04-25-2011 02:17 PM
Anyone know the stock jetting, and float level for a stock Cr250? (1988) CheM 2-Stroke Dirt Bikes - Honda 2 02-03-2005 06:49 PM
Factory Fatty Vs. Fatty redryder250 2-Stroke Dirt Bike Forums 4 09-28-2004 06:55 PM
Difference of FMF factory fatty or FMF fatty? mattdcs 2-Stroke Dirt Bike Forums 13 06-11-2004 09:48 AM
Will a stock CRF450 beat a stock Preditor? CaRdinalFan450 4-Stroke Dirt Bikes - Honda 5 01-20-2004 05:08 PM
