Belray MC1 oil - caused failure?This is a discussion on Belray MC1 oil - caused failure? within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; I have been using Belray MC1 synthetic oil now for 20 years mixed at 50:1. I use it in my ... |
| Just like you I've run Bel-Ray MC1 in every 2 stroke that I ever owned with no problems. Even before I went to work for Bel-Ray, I would say it was just bad luck or he didn't re- jet the bike properly. |
| 50:1???? what, I used to run that oil, and i used it at 32:1... |
| A 125.........50:1.........okay I'd say its your fault Last edited by superrooster; 04-26-2005 at 07:15 PM. |
| I've been running Amsoil in my 125 for a couple months, with zero problems. I ran Amsoil in my 250 for a week or two (riding every day), with zero problems. I ran out of Amsoil one day, so I used some Bel-Ray MC1 at 32:1, and my crank bearings blow out 10 minutes into that ride! Come to find out.....the bearings were blown because of oil starvation, needless to say, I won't be running MC-1 anymore! |
| Im with big maico id say it was something else and you shouldnt doubt it if you have run it for years. I swear by belray i use h1R in all my bikes it is rated at 40:1 but the mc is rated at 50:1 on every engine. I wouldnt hesitate to run mc1 if i didnt like this H1R so much. Id say it was another problem. |
| Well, if you have been using bel ray for 20 years at 50:1 that pretty much settles it. I don't know why people insist that it would blow an engine or something at anything less than 32:1. I mean don't you think it would be kind of bad for bel rays business if they had tons of people blowing their motors while bel ray laughed it up? |
| This is not the oil's fault. It could be a case of the previous oil and the MC1 not being compatible or it could have just been time for the rod bearing to go. It is a 4 year old 125 and it sounds like maintenance was not high on your buddy's list if he was not even running 2 stroke oil. Chaulk it up to a learning experience and move on. |
| Bel ray makes some great oil. I'm calling it right now, It was probably time that the bearings to go. |
| Well like you said, I have been using it for 20 years with no problems. I will keep using it and chaulk it up as bad luck for him. |
| Read Vintage Dave’s post again. It's spot on. There is nothing wrong with MC1 and after 4 years, the thing is worn out. Blaming the failure on MC1 is just incorrect. If a 2 stroke is ridden around slow (no heat/slow throttle) with no oil in the gas, the lower rod bearing is the first to go in many cases. One more thing, there is not a 2 stroke racer/rider worth their salt that does not shake up their gas mixture before using it. |
| I agree about the possibly worn out engine and the oil not being responsible for the failure. I do believe however, that 50:1 in a 125 is a tad lean...especially since MC1 is not a true synthetic oil. |
| It shouldn't even be a question of oil. If the oil was doing that, Belray would have pulled the product. They test everything. 125's that are 4 years old will have cranks go out right about now. Just the way they work. He also could have had an airleak or anything else that made it go. I personally like 40:1 as well, but that is just me. 32:1 is just too thick and 50:1 scares me a little. But don't worry, it wasn't the oil. Although, Ernie is correct. When running that thin of a mixture, definitely would recommend a fully synth oil. 40:1 is the thinnest I would go on any bike with normal 2 stroke oil. |
| I am not a big fan of MC1 for extended high rpm work. most mx and trail riding it works fine for those I know at 50-1. Was his Suzuki "dry" upon teardown, or like your cr250 Reuel? |
| any idea on what caused this? | mynewcr250 | 2-Stroke Motorcycles - Honda | 2 | 04-30-2009 10:22 PM |
| 125 rebuild failure | chaz24367 | 2-Stroke Motorcycles - General Discussion | 9 | 04-17-2009 11:51 AM |
| Bearing failure | KKXR400R | Motorcycle Suspension Tuning | 18 | 07-08-2008 05:02 PM |
| KawiKid caused splendora to take action | MxMike393 | Photo & Video | 23 | 10-24-2004 06:13 AM |
| Sig failure!! | Frakke | General Discussion | 7 | 03-12-2004 12:34 PM |
