![]() I've wired a two prong plug to my battery for easy access when charging. I hope to be able to hook it too a charger and forget it. Problem is that I don't know the difference in types of chargers. Do I need an automatic "trickle" charger, a "maintainer", or something else. I don't want to overcharge and kill the battery. I just want plenty of power when I decide to go riding. Can someone please explain the difference in types of chargers and advise? |
![]() A maintainer will only keep your good charged battery at that level. It will not recharge a low battery. This should be what you need, for your application. A trickle charger will charge a low voltage battery, but if left on too long it can overcharge it as well. I use low out put solar chargers on all my heavy equipment. Paw Paw |
![]() Thanks I have a charger if ever needed, so I'll get a maintainer. |
![]() The little bicycles advantage more from a rich blend than the greater bicycles do since they truly need the additional pressure. Run it 32:1 for good oil and top end life. You can run it less fatty in the event that you need, yet 32:1 should work for pretty much any bicycle. |
![]() Not all lead-acid car battery chargers are designed to be deep cycle battery charger especially since the needs of a deep cycle battery are drastically different than those of a regular car battery. |
![]() Battery Tender 800 is a good stuff. It is compact and waterproof. |
Thread Tools | |
anyone know the standard nitrogen charge psi 2003 crf 450r? | colorado_rider_450 | 4-Stroke Dirt Bikes - Honda | 3 | 03-05-2014 11:26 AM |
88 cr250 shock nitrogen charge psi? | colorado_rider_450 | 2-Stroke Dirt Bikes - Honda | 8 | 02-24-2014 12:09 PM |
86 CR 125R Shock Charge | Steve0hhh | 2-Stroke Dirt Bikes - Honda | 11 | 09-26-2012 09:57 PM |
rear shock re charge ? | icango | 2-Stroke Dirt Bikes - Honda | 13 | 05-25-2012 04:22 PM |
