Old 12-02-2004, 11:09 AM
therapture's Avatar
Last Online: 12-10-2005 10:01 PM
Default ATM from my home PC = no go
I simply cannot get here from home....I get an "access denied" or "server not found" error, started about a week ago....something with my local provider I guess....
I am going to run a tracer tonight and see where it is stopping....but it's not my PC causing it...
Old 12-02-2004, 12:31 PM
Macho393's Avatar
Default Re: ATM from my home PC = no go
leave a pm to Zoot or WoodyCrf
Old 12-02-2004, 12:35 PM
MrsTwister393's Avatar
Last Online: 09-08-2010 07:00 PM
Also check your cookies and delete those, that will keep you from being able to log on.
Old 12-02-2004, 12:58 PM
psyklone393's Avatar
Last Online: 03-27-2006 10:53 AM
what you're getting indicate two different problems. the 'access denied' means you were able to contact the site, however access was not allowed. did it give you an http 403 type of message? the other message is stating that it can't contact the site at all. that could be attributed to dns failure possibly ... if your machine isn't resolving www.allthingsmoto.com to an ip address then it's not going to get here. of course if it failed to resolve all the time then you'd never see the first message. who is your home isp?
-Z
Old 12-02-2004, 01:21 PM
therapture's Avatar
Cox-internet is my ISP........
Old 12-02-2004, 01:49 PM
MotoMan's Avatar
Hey Rapture, not to mess your post up, but how is your recovery coming along?
BTW, you are in EXCELLENT hands with -Z here, that man will get to the bottom of your access problems I can promise that.
Old 12-02-2004, 04:32 PM
Last Online: 06-13-2013 04:37 AM
i had this same problem after i redone my whole system on my old tower. i also believe it is a cookies porblem. you need to go into your control panel and find the proper place to set it. if you see something like "block all cookies" or allow all cookies" this is where you need to be. i cant tell you how to get there, i just open almost all my files till i find it LOL it is like a box that can be checked, it will have a low to a high setting. a normal setting is medium. that should help some, i think
Old 12-02-2004, 11:38 PM
Age is a state of Mind
Last Online: 04-15-2018 10:24 PM
Hey Keith, PM me your IP address at home and I'll make sure you didn't get (via dhcp, assuming you're setup that way, which you probably are) a banned IP address.
Also, when you do a tracert, you will only get as far as the border routers for our host provider (ev1.net, and it does respond), as soon as you get past that point, they drop ICMP packets, so it won't return anything beyond that point.
Old 12-03-2004, 07:26 AM
therapture's Avatar
I did not copy the tracert, but it times out trying to connect, regardless of whether I ping it through the command prompt or via the browser. DNS is working, it resolves the IP just fine, it knows what the site name is....but just times out. Weird. Used to work up until about 2 weeks ago.
I will get my home IP at lunch and send it to ya...
Old 12-03-2004, 08:01 AM
You can't ping it either, as that falls under the ICMP request umbrella.
I'll look for your PM later.
Old 12-03-2004, 12:30 PM
therapture's Avatar
Here ya go...my browser finds the site fine, even says "connecting to allthingsmoto.com"...
....then it just times out....here's a screen cap....
Old 12-03-2004, 07:54 PM
hmmm.... I'm not sure what the deal is. I suppose it could be a routing problem after it enters the EV1 network, although it doesn't seem to be affecting anyone else.
I'll keep checking and let you know if I find anything.
Old 12-03-2004, 08:40 PM
magnethead's Avatar
not to hijack your thread, but how did you pull up that window with CPU clock speed, hard drive temp, and all that?
Old 12-03-2004, 09:19 PM
DPW's Avatar
DPW DPW is offline
Do you have the same issue when using Internet Explorer, looks like you are using FireFox for your browser right now?
Do you have a firewall at home that may be blocking the IP ?
Similar Threads for: ATM from my home PC = no go
Cody is home 4/28 RRsis393 General Discussion 9 04-30-2006 03:54 PM
New Home Page! Madman393 Site News 0 01-10-2003 04:30 PM
