Old 03-10-2017, 02:25 PM
Last Online: 03-11-2017 02:26 PM
Default 1997 cr125 Will not hit power band
Hi, I have a freshly rebuilt 97 cr125 that will not hit the power band. Once going past about half throttle the bike will just sputter and pop and wont go anywhere. When I sent in the cylinder to get bored I also had them rebuild the power valve so I wouldn't think it would be a powervalve issue.. Also when I go to kickstart the bike the kickstart lever kicks back at me almost every kick, could this be timing related or something else? The bike did these things before the rebuild too. It runs fine on the low end, sounds good and everything just wont hit the band.
I have a video of the issue but it wont let me post it. :/
My jetting is
175 main
50 pilot
needle on the third clip
air screw 1.5 turns out.
My reeds are in good condition no holes or cracks
If anyone has any ideas what I should check or if you need more info please let me know! thank you.
Old 03-11-2017, 06:28 AM
Last Online: Yesterday 06:41 PM
Dirty carb, plugged jets, old gas, bad cdi, partially plugged exhaust pipe or timing.
Old 03-11-2017, 02:26 PM
Thanks for the response. The carb is freshly rebuilt, everything is brand new besides the float and the slide, (both are in good condition) The expansion chamber thats on it currently had a hole that was plugged with muffler cement, it doesn't appear to be leaking though. Is there a way to test a CDI to see if its bad?
Old 03-12-2017, 05:17 AM
Check the timing.
Old 03-13-2017, 06:20 AM
Last Online: Yesterday 06:15 AM
Piston in backwards?
Similar Threads for: 1997 cr125 Will not hit power band
'02 KX 250 no power band. GAVINO 2-Stroke Dirt Bikes - Kawasaki 4 10-22-2014 02:18 AM
power band problem 2000cr125r 2-Stroke Dirt Bikes - Honda 17 08-01-2012 11:13 PM
I need help My bike will not rev up and hit the power band mn_rider 2-Stroke Dirt Bikes - Yamaha 23 06-25-2012 08:35 AM
Power Band is not kicking in??? catastrophicmx 2-Stroke Dirt Bikes - Yamaha 10 10-05-2011 10:20 AM
1997 Cr125 Power Valve cr125k2 2-Stroke Dirt Bikes - Honda 1 09-16-2009 10:13 AM
