1978 yamaha Dt175 stuck in first gear
This is a discussion on 1978 yamaha Dt175 stuck in first gear within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; Hello, I am looking at getting a 1978 yamaha dt175. It sounds like an overall good bike, but it is ...
Old 09-14-2008, 12:18 AM
Last Online: 10-23-2008 09:48 PM
Default 1978 yamaha Dt175 stuck in first gear
Hello, I am looking at getting a 1978 yamaha dt175. It sounds like an overall good bike, but it is stuck in first gear.
So, my question is, what could be causing it to be stuck in 1st? And what will it take to fix it? thanks
Old 09-14-2008, 05:49 AM
kschilk's Avatar
What...me worry?!
Last Online: Today 07:46 AM
If it's not making any strange noises, it's probably just a bent shift fork but without tearing into it, it's hard to say for sure. Either way, it'll have to be torn down to parade rest, to find and fix the problem. Shouldn't be a big deal and if it's just the fork, not terribly expensive.
Old 09-14-2008, 11:16 AM
ok, do you think it would be easier to put a new bottom in it?
Old 09-14-2008, 11:21 AM
dose anyone know where i can find a online repair manual, or a diagram on the engine and trans?
Old 09-14-2008, 11:44 AM
kschilk's Avatar
What...me worry?!
Both cyclepartswarehouse.com and bikebandit.com have schematics you can access and print out online. If it's just a bent fork, the rest of the tranny is probably in good shape and if you can do the work yourself, it oughta' be well under $100 to fix it. If you're not experienced with trannys (I don't mean shemales...the other kind), pay the extra and get it done right.
Old 09-14-2008, 12:11 PM
well, i found a bottom end for $40. now what do you think i should do?
Old 09-14-2008, 12:20 PM
kschilk's Avatar
What...me worry?!
For that price, it might be worth swappin'...as long as it's a good bottom.
Old 09-14-2008, 12:33 PM
ok. The guy said it is good, the to end is seized, so i thought i could put the good top end on the good bottom end. How hard is i to put the new bottom end in? Will i need any special tools? thanks
Old 09-14-2008, 01:44 PM
kschilk's Avatar
What...me worry?!
Swappin' is easy enough, the only special tool you'll need is a torque wrench. If you've never done it, though...I suggest you seek experienced assistance. I'm sure you can find someone to come over and "walk you through it"...won't take long.
Not knowing exactly how and why it was seized, I have to urge caution. If it was a "hard seize" (under full power), the crank could be bent, bearings could be trashed, connecting rod could be bent, the crank seals may be blown and there's likely to be debris in the crankcase.
Old 09-14-2008, 01:51 PM
ok. i think he said it was just from sitting for a while.
Old 09-14-2008, 02:22 PM
kschilk's Avatar
What...me worry?!
Man, seriously....you're gonna' give me nightmares! That could be just as bad. I've had to fix a few bikes like that...I actually had to drive (hammer) the piston out of the cylinder. That can certainly ruin a rod & crank. If it's already apart, I'd wanna' know exactly how they got it apart. Also....if it was sitting for a long time, the seals probably won't last...they can dry out and rot or crack. The original rebuild idea, is startin' to sound alot better.
Similar Threads for: 1978 yamaha Dt175 stuck in first gear
1975 DT175 Yamaha Chadwic 2-Stroke Motorcycles - Yamaha 0 02-17-2009 03:56 PM
1978 Yamaha- just bought it- questions... telecomslave 2-Stroke Motorcycles - Yamaha 12 05-09-2004 11:03 AM
1978 Yamaha DT-250 DT-250owner Vintage Riding 3 02-14-2004 08:53 AM
1978 yamaha IT 175 ranger4x4_93 Vintage Riding 3 08-03-2003 12:48 AM
1978 yamaha IT 175 ranger4x4_93 2-Stroke Motorcycles - Yamaha 2 08-02-2003 10:12 PM
