Old 04-19-2012, 12:19 AM
Last Online: 06-16-2015 03:25 PM
Default new to ktm..1993 ktm exc 300????
hey guys, so i came across a nice older bike. bike is in great condition for yr but i know nothing about ktm, or what they are or can do.. can anyone tell me anything about this bike? its a 1993 ktm exc 300.. bike has been totaly gone through by a ktm dealer. all new wheel bearings, swing arm bushings, top to bottom engine inspection, many new parts.. suspension has been rebuilt, carb rebuilt. lots and lots more.. i can get the bike for 700, but he is willing to go lower if need be.. i dont know anything about these bikes, can anyone help? hows the power? i had a 1991 kdx 200.. thought that went well for what it was.. can anyone tell me if it will compare to that? can i do mods to it?
Old 04-19-2012, 10:30 AM
that engine has always been great. like anything of that era the forks are the weak part of the suspension package, but can be swapped out for something from showa or kyb reasonably if you dont get impatient to buy.
Old 04-19-2012, 11:02 AM
is there a big difference between the older 300 engines and the new 300 engines? i see alot of videos of the newer bikes but not many of the older ones
Old 04-19-2012, 11:25 AM
to me they didnt seem too much different in the way they ran. ktm has made a few case changes as they changed the 250. they also did some bore and stroke changes as they flopped around on the 250. I rode a 95 300 with the 73 mm stroke that I believe you have, then a 2005 which I believe changed to a 1mm shorter stroke and a slightly larger bore. the 73 mm stroke hung around for a very long time though.
if that bike is priced where you want it to be, I think you would be happy with it considering what you used to ride and like. for trail, the 95 had a great suspension, but the euro forks don't suit some people. a set of forks and a front wheel off of a cr or yz won't be that hard to put on, and they are plentiful, as in under 400 to do that whole swap easy, if you are patient in your ebay etc shopping.
Old 04-19-2012, 11:43 AM
Thanks man good info. I apreciate the help. So the 300 ktm should be a big change for since im used to riding the kdx 200?
Old 04-19-2012, 11:47 AM
same kind of power only it has lots more of it. :-) top end on one of those with stock gearing is well into the 80's and 90's are just countershaft away. that transmission with it's wide set of gear ratios allows for a whole lot. the clutches on those models don't take what some riders like to do with them now, but you wont need to play clutch slipping games with that engine and transmission.
Old 04-19-2012, 11:51 AM
Nice. They 5 speed or 6?
Old 04-19-2012, 12:29 PM
five speeds, and that engine would work fine with 1 3 and 5
Old 04-19-2012, 12:30 PM
So its geared pretty high from the get go. Wheelies must not be a issue
Old 04-19-2012, 12:37 PM
it has a pretty low low gear, and a high gear lots higher than the mx or mxc versions. you can ride all day in third, stock gearing is good from 5 to 45
Old 04-19-2012, 12:45 PM
Wow thats awesome. Ya im not used to that lol. Im used to the kdx 200 with 6 gears ut the kdx was getting boring so i had to let er go. I found this bike and the guy told me it was totaly looked over by a dealer with alot of new parts including a new top end with 2 hrs on it. Ive had bad luck with bad deals. I bought 2 bikes with suposably a bad top end and come find out the whole engine had to be rebuit and it was gonna cost me 800 to fix. So instead i looked around for something else. Found this ktm and heard good things about them just never owned one. I apreciate all the help.
Old 04-19-2012, 01:06 PM
did you look at it yet?
Old 04-19-2012, 01:12 PM
yes i have, from what i can gather its in great shape.. tires are great and it runs nice. it has a dynoport head pipe, i belive its the stock silencer tho.. tires are great, new front and rear wheel bearings, swing arm bearings, carb rebuilt, jetted, front and rear brake pads, new clutch and cable, topend is new, have all reciepts from the shop..here are some pics..
this is what i got.. il have a video of it hopefully tonight, hes gonna make one for me..
Old 04-19-2012, 01:20 PM
for 5-700 i dont see how you could hurt yourself. even the 43mm forks off the yamahas were a better front unit, and those are really cheap and easy to find. 96-2000 46 and 47mm forks really inexpensive too. you would have the greatest powerband in that class and very acceptable suspension for a good price.
Old 04-19-2012, 01:23 PM
So u think it would be a good bike for the price hes asking? Is it worth it?
Old 04-19-2012, 01:27 PM
I do, yes.
Old 04-19-2012, 01:29 PM
Ok good lol cause i just put money down on it
Old 04-19-2012, 01:31 PM
well you always see how low they will go, but at 7 you probably cant find a better one of it's type. I can th ink of anything from that era other than a wr250 that I would be anywhere near as pleased with. Take the forks and brake off the wr and you have a better bike than either one of them.
Old 04-19-2012, 01:32 PM
Damn man u seem to know alot about these bikes lol
Old 04-20-2012, 12:20 AM
just another ? are these bikes cold blooded? the guy made me a couple short clips, and it seems it sputters alot when he opens it up.. not sure how long he ran it for but he ran it for a minute on the videos and it still sputtered pretty bad. could it be just a dirty carb or something? anything helps.. thanks
Similar Threads for: new to ktm..1993 ktm exc 300????
1993 ktm 250 exc landonwall86 2-Stroke Dirt Bikes - KTM 4 07-23-2011 04:09 PM
ts 185 1993 lucky 2-Stroke Dirt Bike Forums 5 09-10-2009 07:22 PM
1993 kx 125 HELP!!!!!!!!!!!!!!!!!!!!!!! 23kowalski 2-Stroke Dirt Bikes - Kawasaki 6 02-04-2009 11:07 PM
will a top end off a 1997 kx 125 fit on a 1993 kx 125? maverick89 2-Stroke Dirt Bikes - Kawasaki 1 02-25-2008 08:38 AM
will a top end off a 1997 kx 125 fit on a 1993 kx 125? maverick89 2-Stroke Dirt Bikes - Kawasaki 0 02-22-2008 04:19 PM
