KTM Hydrolic Clutch OilThis is a discussion on KTM Hydrolic Clutch Oil within the 2-Stroke Motorcycles - KTM forum, part of the 2-Stroke Motorcycle Forums category; The manuel recommends sae 10w hydraulic oil. The cap on the resevoir says use mineral oil. I am using mineral ... |
| The manuel recommends sae 10w hydraulic oil. The cap on the resevoir says use mineral oil. I am using mineral oil right now but I don't feel comfortable with it. I want to buy a bleeder pump and change to the hydraulic oil. 1.Two questions what do you use in your Katoom clutch? 2. Where do you get it? I looked at our MC shop yesterday and they didn't have any hydraulic fluid. Maybe a KTM dealer might have it? Last edited by Dirtbikindad393; 06-19-2004 at 01:35 PM. |
| i use steel cable in mine. works good too i really have no clue. Rick should know though! CALLING COACH Rob |
| Using the mineral oil is right. Anything else is going to ruin the seals. Why do you feel uncomfortable using it? Magura does make a special fluid for their clutches. |
| Try the Magura fluid then I guess |
Thank You Rockey This is why I love this place I never feel stupid asking questions about bikes. I am also never made to feel stupid for asking them. |
| Quote: We bled the clutch with the mineral oil and it seems to be fine. Its got good lever (if it was a car we would say pedal). |
| DBD: Just go over to KTMTalk & do a serch on clutch oil & you'll get a bunch of info. I think that some guy's are using Mobil1 ATF with good results. I'm about to change mine & I'll just run up to the local KTM dealer as they have the whole kit in the shop for $18.95 You migh check with some of the local moto outlets to see if they have the kits. Cyclegear here in Houston has them on the shelf. |
| Mineral oil in non-toxic, cheap, available almost anywhere in the event of an emergency repair...why do you feel the need to switch. |
| I second Howard's for motion for KTMtalk. I use the search feature for the answer to just about anything! |
| When Stevie was a KTM support rider a few years ago, we always ran mineral oil with no problems. |
| Dane, set the "from" option to the beginning. I got 2 pages of posts using keywords "clutch fluid" and over 4 with "hydraulic clutch"........... |
#18
| Don't use mineral oil from the drug store. Any high quality 5 wt. fork oil will work. I replaced mine with high quality racing fork oil. 5wt makes the clutch work so easy. ATF fluid is about 15 wt. |
#19
| Rick: I hate to disagree with you but ATF is NOT 15wt. Dextron II is 7.5 Wt & ford type is 10Wt. I also told DBD to look up using Mobil 1 ATF which is 7 Wt |
#20
| Howard, I thought the same about ATF fluid, but Shocknut told me it was more like 15 wt. so now I am all confused. |
| Clutch probs- clutch wont dis engage. HELP | EliteDetailOC | 2-Stroke Motorcycles - Yamaha | 14 | 03-07-2010 11:43 PM |
| Clutch cable replaced, but clutch won't work anymore... | 96kx125 | 2-Stroke Motorcycles - Kawasaki | 1 | 07-31-2007 05:16 PM |
| new body know nething about hydrolic clutchs? | pureoctane911 | 2-Stroke Motorcycles - Honda | 1 | 02-13-2005 10:09 PM |
| New Clutch Lever wont Engage clutch | khyz250 | 2-Stroke Motorcycles - Yamaha | 2 | 01-14-2005 02:17 PM |
| 400ex hydrolic clutch | Gman01 | ATV/UTV - Honda | 6 | 09-05-2003 02:31 PM |
