Old 05-15-2016, 07:25 AM
Last Online: 09-23-2016 03:49 PM
Default Ktm 125 2009 rear brake sticking
Went riding on a enduro track yesterday was quite wet after a while all of a sudden my rear brake locked up then freed itself a hour later the same thing it kept happening! Last week it stopped working totally and I run out of fluid for it so I used clutch mineral fluid as a emergency not sure if this is what's causing it but the wheel is now turning but it's very stiff like it's rubbing! Anyone have any ideas ? Iv attached a link with a picture of the rear calliper
ollyh2015's Library | Photobucket
---------- Post added at 01:25 PM ---------- Previous post was at 01:22 PM ----------
Link should work I hope anyway photo is in my album
Old 05-15-2016, 08:09 AM
2 stroke bloke's Avatar
Last Online: 12-16-2016 09:57 PM
Time for new pads I'd say.
Before you replace them, pull the caliper apart and grease everything. Get any surface rust etc off with a bit of wet and dry sand paper, then steel wool before grease.
Look at the pin for instance. The brake pad needs to slide along that to re-align themselves.
Fresh fluid and a good bleed should see it right. There's plenty of how to vids on you tube.
Old 05-15-2016, 08:17 AM
I'm getting them tomorrow, strange why the brakes sticking on though, it had new pads like a month ago I only ride once maybe twice a week they've worn down so fast. I'm useless with calipers but I'll give it a go
Old 05-15-2016, 05:22 PM
Most likely beause they're not disengaging properly.
I find the Bendix, or Braking sintered pads last the longest for me.
Old 05-17-2016, 09:18 AM
i dont understand it cos the piston is moving freely in and out, i cant get pressure to build up or even fluid out the nipple think the master cylidner is goosed, its going in shop for master cylinder rebuild n hopefully back to normal reayd for weekend! whats best for keeping chain lubed up its a new chain and keeps drying out after one ride n a wash
Old 05-17-2016, 04:42 PM
As soon as you finish washing the bike. Spray the chain with a de-watering fluid. Or, CRC, WD-40, Inox etc.
Similar Threads for: Ktm 125 2009 rear brake sticking
CR250 Rear Brake Rub. HELP! beetlejuice 2-Stroke Dirt Bikes - Honda 1 03-17-2013 11:57 AM
KX80 Rear Brake KT67 2-Stroke Dirt Bikes - Kawasaki 0 10-09-2012 11:09 PM
tapping rear brake in the air kawamama3 4-Stroke Dirt Bike Bike Forums 7 05-09-2008 02:52 PM
'93 KX250 rear brake sticking ThumperCRF250 General Discussion 0 06-25-2006 01:53 PM
Touchy rear brake ? smileyman 4-Stroke Dirt Bikes - Yamaha 7 02-26-2005 09:10 PM
