Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 2-Stroke Motorcycle Forums > 2-Stroke Motorcycles - KTM
Big Ole Problem Help!
This is a discussion on Big Ole Problem Help! within the 2-Stroke Motorcycles - KTM forum, part of the 2-Stroke Motorcycle Forums category; I am willing to bet that oring nailed it, sounds like a re-occuring problem and that sounds like a fix ...
Old 11-10-2004, 08:22 AM
MotoMan's Avatar
Floppy
Last Online: Today 09:40 AM
Default Re: Big Ole Problem Help!
I am willing to bet that oring nailed it, sounds like a re-occuring problem and that sounds like a fix to me.
I know on most bikes you can leave the powervalve arm cover off and go down the road and actually watch to see if the valve is opening and closing, I have done this on a couple of my yz's.
Let us know what you find Dane.
Old 11-10-2004, 12:21 PM
Dirtbikindad393's Avatar
Your ATM Amsoil Dealer
Last Online: 01-25-2010 11:59 PM
I will Motoman. I hope thats it.
Old 11-10-2004, 01:20 PM
SirFallsALot243's Avatar
AKA Ineedabettrbike
My first thought when I read the first post was the powervalve. Scott (spitfire)'s RM125 did the exact same thing when it was unhooked.
Old 11-10-2004, 02:17 PM
Well I called my local shops to see if I could get it in but of course it's too late in the game to get it done for Mesquite. I will look at it tonight best I can and see if its the power valve and if there is anything I can do for it.
We might just bring it with us and see if there is anything we can do out there also. DBK might be riding my bike while I am not riding. I feel really bad about this. He was really looking forward to riding his bike at Mesquite.
Old 11-10-2004, 03:07 PM
I've been RM-Zedded
mmmm.. some wrenching at mesquite... what good would the trip be with out some mechanicing?
Old 11-10-2004, 04:13 PM
True dat
Old 11-10-2004, 04:31 PM
Spitfire's Avatar
Banned
Last Online: 08-10-2006 01:25 PM
My bet goes toward the powervalve. Like Ineeda said, my bike's powervalve (RM 125) wasn't working for the first 3 months+ I owned it. It would idle fine, bottom end power into the mid-range power was fine (powervalve was stuck closed), but it just wouldn't scream, or have ANY powerband, so we took apart my powervalve, and it was full of carbon, cleaned it, thought the problem was solved, nope, so we checked out behind the right side cover, and sure enough the actuator arm was unhooked down there, put that on, put everything back together, with the exception of the linkage cover, started it, revved it up, and you could see the actuator arm moving, so we then knew it was working, took the bike for a spin (after putting linkage cover back on of course), and one word could describe what that bike was like, WOW!, it honestly felt like a brand new bike. So yeah, I'm betting it's your powervalve giving ya trouble, simple fix though!
Old 11-10-2004, 05:09 PM
I hope its simple. I am not sure how you would rehook it if its not hooked. I looked under that cover last night but couldn't tell anything.
Old 11-10-2004, 05:22 PM
Spitfire's Avatar
Banned
There's a diagram to my powervalve/linkage, I'm not sure if your KTM is the same, but I couldn't find a diagram for KTM on BikeBandit, so maybe this will help.
What was wrong with my bike was very simple, following the diagram, Part 37 (attached to Part 35), fell out of the little hole in Part 27.
Old 11-10-2004, 08:30 PM
OK I think I have solved the problem thanks to you guys here.
I got home took the right side cover off like Spitfire and Oring said and sure enough the rod pushing up on the thingy to open the power valve was disconnected. My problem is not knowing how it works, I took everything apart and cleaned it too. Putting it back together is a pain in the azz but it will be done soon and I will test it out.
I will post whats up in a little bit. Thanks for the help gang!
Old 11-10-2004, 09:03 PM
I've been RM-Zedded
Right on DANE & ATM.
Old 11-10-2004, 09:07 PM
dbc dbc is offline
I've owned some KTM smokers, and there's plenty of info at KTMTALK on how to properly set up the power valve. It's also covered in the owner's manual. Tricky, but not that difficult.
Good luck, let us know how it all came out...
Old 11-10-2004, 09:42 PM
Holy Cow I forgot how much power that little thing has.
Problem solved!!!!!!!!!!!!! It was the power valve and thanks to the ATMers its fixed. The tips on how to check the inspection cover and a little ambition and vunda bah.
Thank you Thank you Thank you all that helped with tips and advice. Now then, we need to find out if we are going or not.
The little beast is ready and so is the Blue Beast.
Thanks again everyone.
Old 11-10-2004, 09:45 PM
I've been RM-Zedded
Wooo HOOOOOOOOO
Old 11-11-2004, 12:47 AM
Dirtbiknkid's Avatar
Small riders dream BIG!
Last Online: 01-27-2009 07:40 PM
Thank you everyone that put their imput in. I am very happy that the bike finally runs.
Old 11-11-2004, 08:40 AM
Aussie@Down Under!
Last Online: 01-22-2006 08:02 PM
Excellent!
Old 11-11-2004, 09:33 AM
psycho393's Avatar
I got DUALS
Last Online: Today 07:04 AM
Very good. Hope you go
Old 11-11-2004, 10:20 AM
twoofeach's Avatar
AKA clicea
Great news...no thanks to me.
Old 11-11-2004, 12:33 PM
ROFL you fundy Two!
Old 11-12-2004, 08:30 AM
MotoMan's Avatar
Floppy
Excellent news!!!
Similar Threads for: Big Ole Problem Help!
YZ 125 problem mxracer18 2-Stroke Motorcycles - General Discussion 1 06-23-2008 08:33 PM
05 FCR bog problem Aint-Right ATV/UTV - General Discussion 2 04-12-2005 05:03 PM
No first gear problem solved / now problem with PV Crazy 2-Stroke Motorcycles - Yamaha 2 07-10-2004 03:58 PM
Anyone ever had this problem? CRacer 2-Stroke Motorcycles - Honda 5 03-26-2004 11:45 PM
