Old 12-05-2011, 06:42 PM
Last Online: 02-07-2012 05:36 PM
Default 2010 250xc fork oil
How much fork oil do I add when changing my seals? Seams like any seal in a ktm doesnt last long.
Old 12-05-2011, 08:22 PM
bbrmotosports's Avatar
Rockin A class
They take 350 cc from complete disassemble
Old 02-26-2012, 03:34 PM
Last Online: 02-22-2013 05:55 PM
Talking
Ever try the film trick ? That is take a piece of old 35 mm film and slide itin and around in a sweeping like motion to pull out dirt particles but before you do this clean area well with brake cleaner and then lube film with fork oil you can also use a piece of microfiche somebody actually makes a tool for this now but i can,t remember who
Old 02-26-2012, 03:52 PM
Last Online: Yesterday 05:35 PM
Motion Pro makes the "special tool". You can also use a thin feeler gauge blade to do the same thing. If you are not familiar with this little trick, look up "motion pro seal mate" on youtube. They do a demo on there.
Old 02-26-2012, 07:28 PM
Crogg's Avatar
Last Online: 03-14-2019 09:10 PM
First off you don't need to change the inner chamber fork oil when changing seals, so aprox. 12 oz. in each outer chamber is all that is needed. Second, if you're fork seals aren't lasting very long you need to replace the bushings, they are worn out. Third, you can use a Yamaha 48mm fork seal instead, it will save you some $ and last longer. The outside diameter is oh so slightly larger and is harder to get it but will work with excellent results! Been two years since I put in a pair on my buddy's 07 300XC.
Similar Threads for: 2010 250xc fork oil
honda crf250x vs ktm 250xc-f hondacr 125 What Dirt Bike or ATV 2 02-27-2012 03:06 PM
Right side fork really bouncy after changing my fork seals. jrhockey03 Dirt Bike Suspension Tuning 2 05-07-2009 06:31 AM
2008 KTM 250XC Only 10 Hours Indiana SlyFoxMx Classified Ads 0 10-23-2008 07:52 AM
07 250xc OMA Race Bike! (pics) ChrisBach14 2-Stroke Dirt Bikes - KTM 10 08-26-2007 02:59 PM
01 CR250 fork protector rubbing on fork tube AustoUS 2-Stroke Dirt Bikes - Honda 15 08-26-2006 03:30 PM
