Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 2-Stroke Motorcycle Forums > 2-Stroke Motorcycles - KTM
2000 50 cc 2 stroke hard starting
This is a discussion on 2000 50 cc 2 stroke hard starting within the 2-Stroke Motorcycles - KTM forum, part of the 2-Stroke Motorcycle Forums category; this is the first small 2 stroke I've had, the last 2 stroke I had was 15+ yrs ago (full ...
Old 04-21-2009, 12:49 AM
Last Online: 04-24-2009 11:10 PM
Default 2000 50 cc 2 stroke hard starting
this is the first small 2 stroke I've had, the last 2 stroke I had was 15+ yrs ago (full size), I bought this used for my little guy, he's jonesing to ride it and I can't get it started,
I have done all the normal things:
cleaned outed carb (bike sat for 1-2 years un started in that time)
not sure of factory settings on mix screws (currently at 1.5 turns out, both of them)
new spark plug
Checked spark (good)
Checked compression (about 80 psi)
fresh fuel
AND kicked until all (dad, mom, brother & friends) legs are sore.
NO start, just some poping in the pipe,
ANY IDEA'S ????
Old 04-21-2009, 01:18 AM
ctroger24's Avatar
Last Online: 11-17-2009 05:16 PM
What type of 50 is it? On my sons Pw50 the choke MUST be on and the switch on the start position or it wont start. You might want to check in a manual for what the compression should be on his bike. Also did you check to make sure the plug is getting wet and also that you assembled the carb properly? I bought a cr250 a while back that didnt run and I checked everything. Nothing for 2 days other than a dead leg. Finally, I pulled the bowl off the carb and I realized I installed the floats incorrectly causing the bike to not get fuel. Probably not your case, but I would at least check. it. Good luck!!
Old 04-21-2009, 07:11 PM
HELLDOG488's Avatar
Last Online: 05-19-2009 08:37 PM
8o psi is too low if you did the comp test correctly.....Did you do it with the throttle wide open as you kicked??
Old 04-22-2009, 01:27 AM
Yes I did....... whats normal / good ?
Old 04-22-2009, 05:02 PM
racerfty's Avatar
premix sniffer
Last Online: 10-11-2009 10:41 AM
i am not sure if it even has reeds, but on my 125 i had that problem, kick and kick, and all i got was a pop or two out the exhaust, turns out the one of the reeds were chipped.
Old 04-22-2009, 05:29 PM
HELLDOG488's Avatar
should be about 130 psi......for a engine to run 100 psi should be the lowest
Start there.....and while doing that check the rod and main brgs for play also..
Old 04-23-2009, 08:18 AM
mnewmanfla's Avatar
Last Online: 04-30-2009 08:36 AM
What kind of bike?
Please provide the information.
Have you tried to put a little fuel in the head and start it?
Break it down, you need three things to make it run...
Spark, Fuel, Air.
Lets find out what's going on.
Post some more info.
Old 04-23-2009, 07:06 PM
HELLDOG488's Avatar
AND........compression
Old 04-23-2009, 08:18 PM
ctroger24's Avatar
He said his compression was 80psi.
Old 04-23-2009, 08:28 PM
HELLDOG488's Avatar
Yeah i know and thats toooooo low....
Old 04-23-2009, 08:37 PM
mnewmanfla's Avatar
Yep, didn't see that... Compression is way too low to run.
Rated at 135 psi, it's not gonna run at 80 psi.
Good luck
Old 04-23-2009, 08:42 PM
HELLDOG488's Avatar
Pull cylinder and see what letter it has stamped on it.......Cause that will save you time on ordering the parts you need
Old 04-23-2009, 11:13 PM
Thanks for all the help...... any after-market parts or just the factory?
Old 04-24-2009, 03:32 PM
HELLDOG488's Avatar
stick to factory...
Old 04-24-2009, 11:10 PM
Where do I find the letter on the cylinder?
Old 04-25-2009, 04:58 PM
HELLDOG488's Avatar
Pull cylinder... on the bottom...Which model/motor is it??...in 2000 a few different motors were used....
Similar Threads for: 2000 50 cc 2 stroke hard starting
hard starting Michael Parker 2-Stroke Motorcycles - General Discussion 20 01-17-2008 02:48 PM
Hard starting YFZ after it's warmed up. yfz450alterego ATV/UTV - Yamaha 53 10-17-2005 10:49 PM
Help, hard starting CR CRs4life 2-Stroke Motorcycles - Honda 26 02-16-2005 02:06 PM
Hard Starting XR250 chrisb12002 4-Stroke Motorcycles - Honda 3 02-29-2004 07:41 AM
hard starting kdx 200 jayblaze 4-Stroke Motorcycles - General Discussion 4 01-25-2004 11:16 AM
